How to convert from Esri Arcsde into File geodatabase ?
spiderman
Forum|alt.badge.img+7
Hello ,
i need to convert from EsrI Database Arcsde Geodb to write into Geodatabase (File Geodb Open Api)
Feature reader :to read all feature classes in Arcsde
feature write :file geodatabase
my target to write specific feature classes that belongs to one Feature dataset from Esri Arcsde into file geodatabase
i need exactly sample of feature dataset to test in ArcGis pro .
FME 2021
Thanks in advance
hkingsbury
Forum|alt.badge.img+62
  • June 5, 2023
FME Quick Translator (a separate program to Workbench) will make quick work of setting up the foundations to convert from SDE to GDB
spiderman
  • June 6, 2023
should i write only the name of required dataset at dataset field that I would like to export ?
and it will export only the specific dataset required including feature classes belongs to it .
second question ,about the output will be write in dynamic schema or ….
hkingsbury
  • June 7, 2023
Once you've file out the connection file details under Parameters, clicking on the small three dots next to the dataset field should load up a list of all features classes from which you can select the one you're after
