How can I upload over 20 pdfs on AGOL using ArcGISOnline Connector transformer?
  • Sep 15, 2023 5:23 PM UTC
  • 133 views
jaygrg111_
Forum|alt.badge.img+9
I want to upload several pdf maps to AGOL, which I am downloading from Sharepoint. How can I upload over 20 pdfs on AGOL using ArcGISOnline Connector transformer?
Best answer by j.botterill
Hi jaygrg, yes it should be feasible. You would need to pass all 20 into the arcgisonlineconnector with upload action. The file parameter would be an attribute value of the filepath. So before the connector, place a reader or feature reader with format = directory file path
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/path/path.htm
then in the connector use the @value(path_windows) for File
j.botterill
Forum|alt.badge.img+69
  • Sep 16, 2023 6:58 AM UTC
jaygrg111_
  • Sep 17, 2023 5:15 PM UTC
Hi @jamesb16otterill​  yes it worked perfectly. Thank you so much!
