HI, I was going through the 'FME Server Authoring Manual'. I tried the same credentials provided on the manual to 'add web connection'. But a pop up with "Unable to authenticate using the specified connection information" is appearing. Can someone
training manualWorkspace where I tried the credentials
Best answer by samatsafe
Hi @jobinjose​, to further build on @hkingsbury​'s response, these instructions assume you have FME Server installed on your local machine. If you use a shared FME Server managed by your organization, you will have to enter the connection details for that instance instead. If you do not have access to FME Server, you can request a trial here and install it locally. Hopefully, that is helpful.
hkingsbury
Forum|alt.badge.img+59
  • August 7, 2022
If you go to FME Server in your browser, do those credentials work?
samatsafe
Forum|alt.badge.img+8
  • August 8, 2022
  • August 22, 2022
@hkingsbury​ @samatsafe​ , Thank you very much for your replies. Sorry, I didn't install FME Server on my local machine. I'll install and try again.
