Help in creating a function to create points from a messy csv file
  • Apr 13, 2021 5:28 AM UTC
  • 45 views
I received some data where x and y coordinates are concatenated in a single cell. Extracting and connecting these together will give me either a line or a polygon.
I have provided a sample csv file below
The issue with the data I have been provided is that it has displaced field 10 onwards - but I can't tell that field 10 has been displaced unless I remove the all the concatenated geometry fields
There are 2 things that I need help with
1) extracting the x & y's so I can create geometry
2) understanding where Field 10 may have been displaced to so I can create a table that makes sense!
Any help appreciated!
DanAtSafe
Forum|alt.badge.img+23
  • Apr 13, 2021 6:46 AM UTC
Hi @abbas_lokat​ My general method would be to translate the XLSX to CSV, then read it back as a text file to get the entity_id and concatenate the remaining values to Well Known Text and finally create lines with a GeometryReplacer. Please try the attached workspace. (I don't know if this method helps with Field 10 or not.)
