Has anyone encountered an error in creating a python folder when installing FME Desktop on a windows 10 home computer? How do I get around this, as the problem is preventing the install?
  • Jan 29, 2022 1:21 AM UTC
  • 89 views
theo
Participant
  • Jan 29, 2022 4:46 AM UTC
Hi @Michael Quiring​ , did you try a suggestion provided in this Q&A?
FME Desktop Setup Error: An error occurred while attempting to create the directory: C:\\....\\Document\\FME
theo
Participant
  • Participant
  • Jan 29, 2022 5:35 AM UTC
I haven't yet tried this. I'll give it a try. Thanks
theo
Participant
  • Participant
  • Jan 29, 2022 8:15 PM UTC
Well what a lot of bother that turned out to be. The Virus and Threat Protection tab in Windows Security wasn't available. So after much research, I had to edit the registry to make it reappear. Once that was done, I turned off the settings for Virus and Threat Protection and was able to then install the latest FME Desktop sucessfully.
hkingsbury
Forum|alt.badge.img+73
  • Jan 30, 2022 7:43 PM UTC
Also worth running the installer as administrator (if the above doesn't work)
