FME Form 2023.1 Feature Inspector is missing Value column
  • Sep 7, 2023 2:12 PM UTC
  • 96 views
mgrimnes
Forum|alt.badge.img+9
I'm trying out FME Flow 2023.1 and need to run my workspace with breakpoints. When I reach a breakpoint, the Feature Inspector pops up, as expected, but I'm unable to inspect the attribute values. A new column containing the Data Type of an attribute has been added and the Value column has dissapeared. The only thing I can adjust is to show the Data Type column or not.
This makes the usage of breakpoints and feature inspection almost useless. I'm interrested in viewing the values for each attribute, the data type is rather irrelevant.
Best answer by jovitaatsafe
@mgrimnes​, you've probably already gotten the update from the support case email, but for anyone else who comes across this, I'm pleased to share that the issue has been resolved for FME 2023.1, and this fixed version can be downloaded from: safe.com/downloads
Happy FME'ing!
daveatsafe
Forum|alt.badge.img+24
  • Sep 7, 2023 9:33 PM UTC
Promoting to support case
mgrimnes
  • Sep 8, 2023 6:57 AM UTC
Perfect!
For me, comming from software development, the use of breakpoints is rather in my backbone, so I'm lost when the single most important info for me to use when setting breakpoints is missing. I know I can enable Feature Caching to acheive something similar. But if you run through a lot of data, trying to figure out what has happened may be a bit time consuming and also a bit hard to follow.
I'm hoping for the best - the return of the Values-column in Feture Inspector!
jovitaatsafe
Forum|alt.badge.img+11
  • Oct 5, 2023 11:19 PM UTC
Happy FME'ing!
