FME case sensitivity in a non-case sensitive database ??
  • Mar 15, 2022 10:46 AM UTC
  • 10 replies
  • 347 views
lifalin2016
Forum|alt.badge.img+41
I'm restoring some data from/to a MS/SQL database, which has been stored in a PostGIS database.
PostGIS lowercases all attributes, and I'm getting errors in FME when writing them to the original database, where attribute names are mixed case. The database itself uses collation Danish_Norwegian_CI_AI, i.e. Case Insensitive.
FME is case sensitive, and I presume that's why it throws this kind of error:
Existing table for feature type `PARKER.d_basis_attribs_kontrolflader_traer' does not have attribute with name `tr_bemaerk'. Cannot continue
The database table has an attribute TR_BEMAERK, i.e. as uppercased.
How come FME doesn't respect the case INsensitivity of the target database ?
It feels kinda stupid to have to rename all attributes needlessly, and no, they're all very mixed case, not all uppercase.
(still) using 2020.2
  • Mar 15, 2022 10:58 AM UTC
Did you import the target table structure into FME?
The table collation shouldn't have any bearing on the column or table names.
lifalin2016
  • Mar 15, 2022 12:43 PM UTC
This is how you query a case insensitive database to check whether a column exists:
SELECT
s.[name], T.[name], c.[name], ty.[name]
FROM
sys.[schemas] [s] WITH(NOLOCK)
INNER JOIN sys.[tables] [t] WITH(NOLOCK) ON T.[schema_id] = s.[schema_id]
INNER JOIN sys.[columns] [c] WITH(NOLOCK) ON c.[object_id] = T.[object_id]
INNER JOIN sys.[types] [ty] WITH(NOLOCK) ON ty.[user_type_id] = c.[user_type_id]
WHERE
s.[name] = 'Parker'
AND
T.[name] LIKE 'D_BaSiS_attribs_KontrolFlader_TRAER'
AND
c.[name] = 'tr_bemaerk'
The result is:
query result
lifalin2016
  • Mar 15, 2022 12:44 PM UTC
I have the attributes from the PostGIS table, which FME won't match to my MS/SQL table.
  • Mar 15, 2022 12:57 PM UTC
There's a good probability that FME double-quotes the column names when doing the insert statements, which means that the column names are case sensitive.
Which means that if you're writing into an existing table, you need the writer attributes to 100% match the destination table. The easiest way to ensure this is to import the feature type from the target database.
  • Mar 15, 2022 1:07 PM UTC
SELECT
FROM
WHERE
s.[name] = 'Parker'
AND
AND
The result is:
query result
When you're comparing field values, like above, collation is indeed applied. But collation is not applicable on column or table names referenced in DML statements, such as INSERT.
lifalin2016
  • Mar 15, 2022 1:22 PM UTC
These "values" are from the system tables, that inform on schemas, tables, columns etc.
Collations in MS/SQL are much more than text comparisons. As I wrote, we use Danish_Norwegian_CI_AI, which defines the character order, whether or not it's case sensitive, and whether or not we should respect diacretics (?), i.e. special consideration for e.g. our "extra" Danish wovels: Æ, Ø, and Å.
My query just shows how to extract the correct cased names from the system tables, it has nothing to do with my current problem.
lifalin2016
  • Mar 15, 2022 1:24 PM UTC
Escaping has nothing to do with case sensitivity. It's a setting on each database.
  • Mar 15, 2022 1:41 PM UTC
Except for in bulk mode, I believe: https://docs.microsoft.com/fr-ch/archive/blogs/yingqin/column-mappings-in-sqlbulkcopy-are-case-sensitive
Try switching off bulk mode on the writer and see if that changes the behavior. It'll be slower, however.
lifalin2016
  • Mar 18, 2022 1:58 PM UTC
Well, bulk mode is usually the first thing I turn off when I encounter problems ;-)
Unfortunately it doesn't change anything, FME still makes case sensitive comparisons of attribute names, which makes sense, since the error is encountered before the data transfer is commencing.
I ended up creating a work-around, saving the data in a parallel schema, and using T-SQL to transfer the data to the final tables. This works with no case sensitivity involved.
  • Mar 18, 2022 2:02 PM UTC
I completely agree re bulk mode: It's great when it works, but a nuisance when there's a problem. Thanks for sharing your workaround, that's pretty clever.
