FME 2020: How to show the records of the selected features in the table?
  • Feb 1, 2021 7:29 PM UTC
  • 7 replies
  • 429 views
jamal
Forum|alt.badge.img+5
I couldn’t figure how to show the records of the selected features in the table. This command is already available in ArcGIS
Clip_338
Clip_339
Clip_340
hkingsbury
Forum|alt.badge.img+73
  • Feb 1, 2021 9:48 PM UTC
Enable the Feature Information window - this will show all the properties for the selected feature
Screenshot 2021-02-02 104345
You can also create a filter that will show only the filtered features in the table
Screenshot 2021-02-02 104549
Remember that ArcGIS is a fully fledged GIS, whereas FME (Data Inspector/Visual Preview) is simply a tool to view data. Often i'll check data in ArcGIS instead of Data Inspector as I know i want to do more complex filtering/validation
jamal
  • Feb 7, 2021 9:19 PM UTC
I didn’t mean to show the attributes of the selected feature but rather to ONLY display the selected features in the table
Clip_366
hkingsbury
  • Feb 8, 2021 8:41 PM UTC
Clip_366
you'll need to set a filter in data inspector (not Visual Preview) alternately set a tester to do the filter you require and view in Visual Preview
jamal
  • Feb 8, 2021 8:58 PM UTC
I thought that there is similar tool in FME equivalent to the one in ArcGIS to show the selected features like simple icon on the table
raymondbrunner
Forum|alt.badge.img+11
I have the same question.
I am wanting to use the visual preview to assess the results of a workspace.
Using the Select tool I draw a box around an area of features (highlighted here in yellow).
The 27 records of 15,367 highlight in blue in the Table View, but are buried among the entire dataset. How do I (temporarily) focus the table on just the 27 selected features?
I can "Save Selected" out to an Excel spreadsheet, but that seems to be an unnecessary step for a quick review of the data.
connecter
Forum|alt.badge.img+10
  • Mar 11, 2021 9:10 PM UTC
Yap, the DataInspector is sufficient for a quick look at your data, but for more I took a normal (Q)GIS. Some feature for inspecting data like sorting or see all highlight items in the viewer are missing.
Please vote for the ideas here:
https://community.safe.com/s/idea/0874Q000000Tl7gQAC/detail
https://community.safe.com/s/idea/0874Q000000TlWCQA0/detail
jamal
  • Mar 13, 2021 5:31 AM UTC
Please, vot here:
https://community.safe.com/s/question/0D54Q00008OxAKOSA3/fme-2020-how-to-show-the-records-of-the-selected-features-in-the-table
