Finding X nearest neighbors in a pointcloud
  • September 26, 2022
  • 48 views
markvv
I'm curious if anyone has found an efficient way to calculate the X nearest neighbors in a pointcloud or a set of 3D points from a single 3D point.
My current method is mathematically calculating the distance from point 1 to every point in my pointcloud with the following formula and then sorting by distance.
d (P1, P2)= ((x2 - x1)^2 + (y2 - y1)^2 + (z2 - z1)^2)^1/2
It works but it's not efficient at all.
I'm curious if anybody has a more efficient idea.
Thanks,
Mark
markvv
  • September 30, 2022
A NeighborFinder that can work with 3D points would probably do the trick.
Is this on the roadmap?
geomancer
Forum|alt.badge.img+56
Maybe buffer the single 3D point with an appropriate amount, and only consider the points (or the part of the pointcloud) within the buffer.
