Fill Properties using the SharePointOnlineConnector
  • September 12, 2023
  • 40 views
nielsgerrits
Forum|alt.badge.img+58
I wonder if it is possible to fill in the properties of an image when uploading this with the SharePointOnlineConnector.
SharePointPrintscreenI tried setting up an AttributeCreator setting "Inspection Title" etc. but it didn't do anything with the created attributes.
Best answer by david_r
I believe you have to use one or several HTTPCallers to attack the specific MS Graph API of your Sharepoint instance, see https://learn.microsoft.com/en-us/graph/api/resources/sharepoint?view=graph-rest-1.0
You can use the same web connection in the HTTPCaller as in the SharepointOnlineConnector.
nielsgerrits
Thanks David, will look into that direction.
In the comments on the SharePointOnlineConnector's hub page I found a suggestion that the Microsoft SharePoint List writer might do this as well.
