Failed to read the metadata for 2D rendering
  • May 17, 2023 10:50 PM UTC
  • 98 views
vxn43
Forum|alt.badge.img+20
I ran a workbench that reads data from .xlsx spreadsheet into a MS Access database (.mdb) table. I got this single error message:
"Failed to read the metadata for 2D rendering"
I have never seen this before, any ideas on what it means and a fix?
I am using FME Desktop Version 2021.2.6 (Build 21821).
Best answer by vxn43
Hi @timh​, we've seen this issue before in the past but it always seems to resolve itself so we're still not quite sure what the cause is. I would suggest updating to the latest version of FME to see if that works, otherwise you can also try the usual things: machine restart, re-adding your reader and/or writer, etc.
If the issue persists, please feel free to file a support ticket so that we can take a more thorough look.
Since I am writing to an existing Access mdb, in Access, I changed the data type in the two date fields from date/time to short text. It still preserved the data in these fields with no changes after the data type change. I re-ran the workbench and it worked with no issues.
saraatsafe
Forum|alt.badge.img+13
  • May 18, 2023 8:29 PM UTC
vxn43
  • May 19, 2023 3:40 PM UTC
