Error overwriting ArcGIS Portal layer
  • Jan 23, 2021 4:19 AM UTC
  • 52 views
cecshi25
Forum|alt.badge.img+5
I was able to create a hosted feature using the same model, but when I switched the writer to update that same layer, it kept giving me this error:
"ArcGIS Portal Feature Service Writer: Could not recognize Feature Service coordinate system '{}'
Python Exception <KeyError>: 'capabilities'
A fatal error has occurred. Check the logfile above for details"
Coordinate System set to EPSG:4326
Portal Feature Write set to Insert and Truncate
Anyone knows how to fix this? Thanks!!
FME_Issue
siriosus
Forum|alt.badge.img+4
  • Mar 31, 2021 9:30 AM UTC
Have the same issue in FME Desktop 2017 x32. Any news/ideas? It seems like common issue with FME and Portal feature service writers. Never succeed in trying to write to the Portal DataStore.
