DATETIME CALCULATION FOR MINUTES
  • Oct 9, 2023 4:44 AM UTC
  • 8 replies
  • 290 views
fme
Forum|alt.badge.img+7
Q1. I need help adding 15mins to the this datetime:
5/10/2023 06:45 PM
Q2. I also want to be able to pick two datetime points to calculate the duration in hours.
Eg. (a) 5/10/2023 07:00 PM (b) 5/10/2023 12:00 AM
Tried several options but can't get it to work. Thanks!
j.botterill
Forum|alt.badge.img+69
  • Oct 9, 2023 4:59 AM UTC
Hi there,
In terms of Q1, you may need to use a DateTimeConverter first, format the input using the quick reference syntax as per following example
datetimeConverterThen use a DateTimeCalculator to add the 15minutes.
dateTimeCalculatorI'll let you calculate Q2 using the above steps
fme
  • Oct 9, 2023 5:26 AM UTC
@jamesb16otterill​  Thanks for the quick response. DateTimeConverter gives me an error feedback after using same configuration in your screenshot. My datetime field is in varchar. I switched it to datetime via attribute manager and it still does not work for me.
j.botterill
  • Oct 9, 2023 5:49 AM UTC
It's fine that it is varchar. First goal with dates is generally to convert it to FME format. Can you copy and paste one of the (date) values so I can test the syntax I suggested is correct
fme
  • Oct 9, 2023 10:33 AM UTC
@jamesb16otterill​  This is the same format as above
5/10/2023 06:45 PM
Thanks!
  • Oct 9, 2023 12:33 PM UTC
5/10/2023 06:45 PM
Thanks!
Try using this format string in the DateTimeConverter:
%d/%m/%Y %I:%M %p
The difference lies in using %I (12 hours) rather than %H (24 hours) for the hour part.
Result:
20231005184500
fme
  • Oct 10, 2023 12:30 AM UTC
%d/%m/%Y %I:%M %p
Result:
20231005184500
@david_r​  @jamesb16otterill​ this did not work either in a Datetime converter. However, I used it in @DateTimeParse in text editor and it worked. But after migrating this to a different version of FME: from 2023.0.1.0 to 2023.1.0.0, none of this worked.
Thanks!
  • Oct 10, 2023 7:46 AM UTC
%d/%m/%Y %I:%M %p
Result:
20231005184500
Weird... I tested it with 2023.1 and no issues.
fme
  • Oct 10, 2023 8:36 PM UTC
@david_r​  I noticed the csv reader in the newer version reading in the year as a 2 digit year instead of 4 digits. This is why its failing.
