CSS Selector
checcosisani
Forum|alt.badge.img+12
Hi
which is the correct css to extratc only the first div
this not work
#tabella > tbody > tr:nth-child(-n+30) > td.text-left > div:first-child
thx
Francesco
Forum|alt.badge.img+39
  • August 10, 2023
Are you looking to extract the first word from that column in each row of the table, i.e. excluding the part in italics and the part in bold?
checcosisani
  • August 10, 2023
Yes
  • August 10, 2023
checcosisani wrote:
Yes
I don't think  you can do that through css selector alone. You should be able to select the entire text with .DataText2 and then use some regex in a stringsearcher to grab just the first portion of text
[\w\s\d]+
checcosisani
  • August 13, 2023
[\w\s\d]+
Ok
also in this case isn't possible to extract the part after span ?
article:nth-child(-n+30) > div > div:nth-child(3)> div > p:nth-child(3) > span
thx
Francesco
