Counter - restart on attribute change
  • October 14, 2020
  • 111 views
Hi all,
I would like to know if it is possible to restart a counter when an attribute in a set of features changes.
I've only succeeded in sorter the entire feature set from 1 -> x.
thx
Pieter
Best answer by ebygomm
Yes, if you set the Counter Name to an attribute value it will do this
Forum|alt.badge.img+39
  • October 14, 2020
  • October 14, 2020
Just to expand on @ebygomm​ 's answer: You can consider the Counter Name as it it were a Group By.
Thank you for the quick reply, after re-reading the help, i realise it's actually stated there as well.
