Convert between different color values
  • Nov 3, 2015 11:01 AM UTC
  • 5 replies
  • 209 views
sigtill
Forum|alt.badge.img+25
Have I missed a transformer to convert to/from for instance RGB 20,255,40 to fme_color?
  • Nov 3, 2015 11:19 AM UTC
Hi
You can use this expression:
@Evaluate(@Value(Red)/255.0),@Evaluate(@Value(Green)/255.0),@Evaluate(@Value(Blue)/255.0
David
sigtill
  • Nov 3, 2015 11:23 AM UTC
Thx! I had a workaround - just seemed to remember there was a transformer to convert between different color schemas - however I guess not :).
  • Nov 3, 2015 11:39 AM UTC
I was also surprised that I was unable to find any. I'll let you post the idea in the suggestion box.
mark2atsafe
Forum|alt.badge.img+59
Maybe it was a custom transformer from the store or knowledgebase that you were thinking about? I see the HTMLColorCalculator - although it only does hex and not RGB. I'll file a suggestion to add that functionality.
mark2atsafe
Added as PR#65379
