Can I read an xml containing horizontal geometry for an alignment chain (in N,E) and have it write out a list of points along the alignment(s) (in lat,long)?
  • Apr 2, 2021 2:08 PM UTC
  • 74 views
I'd like to build a workflow that creates a list of points for each alignment chain from an XML file. Is this possible? The points would be at each end of the alignment and a specified equidistant along the alignment. Is this possible?
caracadrian
Forum|alt.badge.img+23
  • Apr 2, 2021 3:12 PM UTC
Yes. Use Reprojector, PROJReprojector, CSMAPReprojector, or any other reprojector you need to get your data to Lat/Long, then use the DistanceMarker transformer from the FME Hub.
Then just create the attributes you need (with @XValue, @YValue).
  • Apr 2, 2021 3:14 PM UTC
Thanks a lot caracadrian! I'm brand new to FME, so not sure how to do any of this year, but I'll will give it a try. Any suggestions on how to learn how to build this workflow?
caracadrian
  • Apr 2, 2021 4:22 PM UTC
Short answer is https://www.safe.com/training/recorded/
Long answer: figure out what kind of xml you have, use the apropiate reader, get the geometry (GeometryReplacer maybe), create the points along your line with DistanceMarker, reproject to a lat/long projection, use attribute creator to create Lat and Long attributes from point coordinates. So: XML Reader - > DistanceMarker - > Reprojector - > AttributeCreator - > Writer of your choice
  • Apr 2, 2021 4:23 PM UTC
Awesome - thanks for the help!
