intermittent "XXX is not recognized as a valid encoding name. FME Flow 2024?"
virtualcitymatt
Forum|alt.badge.img+42
I have a scheduled automation which runs every hour, it just checks how long the job queue is - the are no user parameters.
Once a month or so I get an ERROR in the workspace.
The error is (log attached):
2025-07-10 09:58:00|   0.0|  0.0|ERROR |'\xA0\xC2y\xDD/Z\x00\x0010 09:58' is not recognized as a valid encoding name.
It’s an old workspace written with FME 2020 that’s been migrated a few times in FME Server to in FME 2024.2.2
The log indicates that something is getting garbled. I can see part of a timestamp in there - the timestamp is the the start time of the job.
I’ve see a similar error in other jobs as well on customer servers as well with different jobs (also intermittent.
Has anyone else experienced intermittent errors like this?
I have a hunch that making a whole new workspace in FME 2024 will make the error go away - but was curious is anyone else had run into this
dylan.at.safe
Forum|alt.badge.img+7
Hi ​@virtualcitymatt
This is definitely an unusual error, and I can't say for certain what's causing it, but here are a few possible explanations:
-Dylan
virtualcitymatt
Thanks ​@dylan.at.safe - that would indeed make sense. I didn't have any trouble with FME Server 2022 but I think the link you shared is probably still relevant here. Indeed the encoding on the machine which created the workspace was probably german encoding and is being run on FME Cloud.
It's just super weird that it's intermittent.
I'm thinking that it could also be getting corrupted or influenced somehow but another workspace which has already run on the same engine before restarting.
