Does FME Desktop and FME Server use these .NET components?
ranga_tolapi
Forum|alt.badge.img+9
Hi, there
Does FME Desktop 2022.2.2 and FME Server 2022.2.2 use any of the below listed .NET components?
  • Microsoft .NET 6.0.29 - Windows Server Hosting
  • Microsoft .NET Runtime - 6.0.29 (x64)
  • Microsoft .NET Runtime - 6.0.29 (x86)
  • Microsoft ASP.NET Core 6.0.29 - Shared Framework (x64)
  • Microsoft ASP.NET Core 6.0.29 - Shared Framework (x86)
If yes, will the upgrade of these components to .NET 8 will cause issues?
Best answer by kate-safe
Hi @ranga_tolapi
Thank you for your post!
I checked with our team and can confirm that we do not use the .NET infrastructure in FME Form or Flow except for a couple of format/transformers (Microsoft SQL Server Spatial (non-JDBC) format, and the MapText Labeler Transformer), so upgrading .NET should not have any impact there.
In addition to that, if you have developed any custom plugins or applications that are using .NET APIs, then we encourage you to reach out to your development team to understand any impacts that upgrading .NET might have there.
I hope this helps clarify things!
kate-safe
Forum|alt.badge.img+10
  • August 7, 2024
Hi @ranga_tolapi
ranga_tolapi
  • August 8, 2024
Thank you @kate-safe, appreciated!
