Writing Raster to PostGis locks table
erik_jan
Forum|alt.badge.img+19
I try to write multiple Raster images to a single PostGis table. Writing the records sequentially is working as designed.
But I am using FME Cloud and want to write records parallel using multiple engines. The first record is written, but seems to lock the table. Therefor all other processes fail.
How can I avoid the table lock in PostGis?
Any suggestions?
Best answer by courtney_m
There is a "Features Per Transaction" parameter on the PostGIS Writer - try setting this to 1. If this is >1, the workspace might be triggering a bulk insert. If this is the case, the first job will issue table-level lock in PostGIS, which will cause the subsequent jobs to fail. If "Features Per Transaction" = 1, each job should only issue a row-level lock in PostGIS for each feature, as it is being written. This will not prevent the other jobs from writing to the same table.
courtney_m
Forum|alt.badge.img+12
  • December 3, 2015
erik_jan
  • December 3, 2015
Yes, setting the Features per Transactions did resolve the problem. Also creating the table before inserting the data, instead of having FME create the table helped.
