When converting DWG to DGN, rotation cells is wrong, solution?
  • January 18, 2016
  • 21 views
Hello
I want to convert a DWG file to DGN. A celllibrary is attached and a correct seedfile. All lines and texts are converted correctly and the unrotated blocks are converted to the right cell as well. The rotated blocks are converted to cells and rotated in the DGN but the rotation totally wrong. I cannot see what the problem is. Units, Settings, I really don't know.
Does someone have a solution? Thx for reading and/or answering!
Mark
erik_jan
Forum|alt.badge.img+21
  • January 18, 2016
Hi Mark,
As the manual notices the rotation is captured in the attribute igds_rotation.
This is the description of the attribute:
The rotation of the entire cell. The rotation is measured in degrees counterclockwise up from horizontal.
Range: -360.0..360.0
Default: 0
Reprojectable: Yes
Hope this helps.
