Suppress warning about FME data type "nvarchar_max" versus SQL "nvarchar(max)"
  • Aug 25, 2023 4:34 AM UTC
  • 118 views
andrewbnz
Does anyone know if it's possible to suppress or otherwise fix the following warning which comes up when writing features to an MS SQL server database?
The column in the database is "nvarchar(max)" but FME always flags this warning when the workspace runs, because it uses "nvarchar_max".
It's only a warning, but when we then deploy this to FME Server/Flow - we regularly check the job logs and these always show the exclamation icon - so just an annoyance as it's not actually an issue.
j.botterill
Forum|alt.badge.img+69
  • Aug 25, 2023 5:26 AM UTC
in 2023, the latest version of AttributeManager has the ability to assign the data type for each attribute. This would be where you could set how FME interprets the nvarchar length, but there is no Max option like SQL. You could try making it nvarchar(4000) width
attributemanager_typeimageYou might be able to turn off "Log Warnings" under workbench FME options > Translation
Then publish the workspace to Flow
log filter message options
