Standard Deviation calculations
  • Sep 4, 2024 7:19 PM UTC
  • 116 views
mr_fme
Forum|alt.badge.img+9
I have an NDVI raster and need to clip it with many polygons. After that, I need to calculate the standard deviation for each piece of the raster (clipped by the polygons), and in the end, I need to correctly assign the deviation value to the attributes of the corresponding polygon.
Thank´s
Best answer by redgeographics
I think you can use a RasterCellCoercer to turn the pixels into points (with the band attributes) and then run a StatisticsCalculator
Forum|alt.badge.img+63
