Split a CityGML file based on gml_id
  • Nov 21, 2019 7:46 AM UTC
  • 6 replies
  • 140 views
Hello,
I'm trying to split a CityGML file into multiple OBJ files based on gml_id. For exemple I have a gml_id like this : "BU_69381A"(A to Z)"39" and I want to split at every letter in brackets.
Do you have an idea of how to do this?
Thank you in advance!
sigtill
Forum|alt.badge.img+25
  • Nov 21, 2019 8:03 AM UTC
Use a StringSearcher and regular expression on the gml_id:
\D{2}_\d{5}(\D)
Explanation:
\D{2} = 2 letters - not digits = BU
_ = underscore = _
\d{5} = 5 digits = 69381
(\D) = any letters at the end of the string = A
All data within () will be saved in a list
Can be tested here: rubular.com
  • Nov 21, 2019 9:00 AM UTC
\D{2}_\d{5}(\D)
Explanation:
_ = underscore = _
This is exactly what I need, thanks @sigtill!
And after how to separate each building letters in 26 OBJ files according to the StringSearcher result? With a Tiler?
sigtill
  • Nov 21, 2019 9:01 AM UTC
Use "fanout" on the writer according to this new attribute. Fanout is described here: https://knowledge.safe.com/articles/565/fanout-1.html
itsmatt
Forum|alt.badge.img+48
  • Nov 21, 2019 9:09 AM UTC
If your CityGML has textures/appearances you might need to be a little careful and put each obj in a separate folder. FME will create a materials file on the same level as the obj so if you write all your objs to the same directory then each time the material file will get overwritten, losing the Information. Just a heads up
  • Nov 21, 2019 3:06 PM UTC
It works perfectly, thank you very much @sigtill!
  • Nov 21, 2019 3:07 PM UTC
Thanks for the information @virtualcitymatt!
