Smallworld Translator Error: No URN handler for class unset
I am trying to migrate shape files data into smallworld by using FME. After configuring workbench i got bellow error's.
  • Smallworld Translator Error: No URN handler for class unset
  • Smallworld Translator Error: Access denied to C:\\FME WORK\\enum_check\\Kofra_enum_log_report.csv.
Thanks in advance for your help.
@golugury Check our notes on Smallworld configuration to ensure that you have all the necessary components installed correctly. I don't think we've see the errors that you have encountered before, but it looks like they are coming from the Smallworld side of the translator. Other resources are - Working with Smallworld and some common connection errors.
pratap
Forum|alt.badge.img+12
  • December 13, 2017
Did you solved this???
