restore a Feature service data
  • May 28, 2024
  • 38 views
hola1115
Hello community,
I've updated an ArcGIS Online Feature Service using FME, but unfortunately, I seem to have lost my data. The table still exists, but the data is missing. The feature service I want to restore was already added as both a feature service reader and writer. Does anybody have an idea how I can restore my data? The 'Enable Feature Cache' option was already checked.
FYI: we only have Arcgis online, we dont have Arcgis Entreprise and portal
kailinatsafe
Forum|alt.badge.img+21
Hello @hola1115, thanks for posting! Seems very odd nothing was written, would you be able to share a full logfile so we can try to see where things went wrong?
A few ideas...
  • Can you confirm all the data is being cached properly before writing (eg. all the data is present in Feature Information window before it hits the writer).
  • Consider sharing a screenshot of your writer parameters, incase we’ve accidentally set a parameter incorrectly.
  • Can you confirm the schema is the same and there are no mismatch is character case?
Unfortunately, I think you will need to recreate the feature service at this time, I don’t think there is a way to reinstate the service. Happy to help, Kailin
