Read files with no line endings i.e. read 100 byte chunks at a time
tim_wood
A colleague wants to read files that have no line ending (either Windows-style CR+LF or Unix-style LF). They have fixed record lengths (100 bytes). Can FME read this type of file (I'm betting it can!)? It needs to process them in 100 byte chunks.
If FME can't do it directly, is there something on the Hub e.g. this?
https://hub.safe.com/transformers/filerawdatafetcher
david_r
  • March 29, 2019
There may be other solutions, but it's fairly easy to accomplish using a PythonCaller, something like:
1class FeatureCreator(object):
2    def __init__(self):
3        pass
4    def input(self,feature):
5        f = open("input_file.txt", "r")
6        chunk = 100
7        while True:
8            data = f.read(chunk)
9            if not data:
10                break
11            newFeature = fmeobjects.FMEFeature()
12            newFeature.setAttribute('chunk' data)
13            self.pyoutput(newFeature)
14    def close(self):
15        pass
Will return one feature with an attribute chunk for each chunk of 100 bytes in the file input_file.txt
bruceharold
Forum|alt.badge.img+18
  • March 29, 2019
i would attempt this with first getting the file into an attribute with AttributeFileReader then making a list from the record layout with AttributeSplitter.
bruceharold
  • March 29, 2019
3        pass
6        chunk = 100
7        while True:
9            if not data:
10                break
14    def close(self):
15        pass
Here i was avoiding mentioning Python and David has no qualms!  The struct module is a candidate too ;-)
david_r
  • March 29, 2019
It's late Friday, my qualms have officially left the building ;-)
david_r
  • March 29, 2019
This is a good solution, given that the input file isn't very (very) large.
tim_wood
  • March 29, 2019
Thanks both for your suggestions. This was partly exploratory to see if FME could be used for this particular job. I'll try make sure I come back and post which solution was used and accept the relevant answer.
