Hi. I have a bunch of xlsx files that are created daily that need to be loaded to PW. They are all in the same directory so I used a TestFilter to separate them out. I can't select the 'File' option on the PW Connector b/c the date changes everyday and the Folder option won't work either. I did have some surface success with Attribute, but the files are corrupt when they land in PW. I am a bit of a newbie, so any help would be appreciated.
