problem when translate DXF
  • Feb 19, 2020 6:18 PM UTC
  • 5 replies
  • 89 views
Hi folks
when i try a translation from DWG to a GIS format, i encounter that message :
FATAL |Incompatible visitor version 1 in FMEOrientedArc::acceptGeometryVisitorConst. This release of FME is compatible with versions 6 to 6
I tried many ways to solve it, GeometryValidator, Orientor, but the message still remains
the DXF file is hudge, so i can't attach to the message ...
regards
Best answer by erik_jan
I was able to read the DXF file and convert to Shape.
This is the workspace:
It is also attached here: dxf2shapefile.fmw
As the DXF contains points, lines and polygons, you will need to create multiple Shape files as shown.
Using the ArcStroker will convert Arcs to lines.
No idea what to do with the Surface object.
The Null geometries can go in either file.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Feb 19, 2020 6:25 PM UTC
The DXF reader has some settings that could help in this case:
  • Store Bulge Info
  • Convert Zero Length Arcs to Points
You can find the information on the settings here
Hope this helps
thanx I look.
No changement , i have tried different toggles with no success
I attach the file ... who knows.PG 17_02_20.zip
the layer used and that causes problem is PLU_PLA_GC
erik_jan
  • Feb 19, 2020 7:44 PM UTC
Hope this helps.
thanx a lot, I use this way ; it works :)
