Hi folks
when i try a translation from DWG to a GIS format, i encounter that message :
FATAL |Incompatible visitor version 1 in FMEOrientedArc::acceptGeometryVisitorConst. This release of FME is compatible with versions 6 to 6
I tried many ways to solve it, GeometryValidator, Orientor, but the message still remains
the DXF file is hudge, so i can't attach to the message ...
regards
Best answer by erik_jan
I was able to read the DXF file and convert to Shape.
This is the workspace:
It is also attached here: dxf2shapefile.fmw
As the DXF contains points, lines and polygons, you will need to create multiple Shape files as shown.
Using the ArcStroker will convert Arcs to lines.
No idea what to do with the Surface object.
The Null geometries can go in either file.
Hope this helps.
The DXF reader has some settings that could help in this case:
You can find the information on the settings here
Hope this helps
thanx I look.
No changement , i have tried different toggles with no success
I attach the file ... who knows.PG 17_02_20.zip
the layer used and that causes problem is PLU_PLA_GC
thanx a lot, I use this way ; it works :)
26 votes
20 votes
18 votes
13 votes
9 votes
8 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
