Postgis Writer - geometry type setter
  • November 16, 2016
  • 20 views
darkspatiallord
Participant
Forum|alt.badge.img+7
Is there a way of setting the Geometry setting on the output feature type with a published parameter?
  • November 16, 2016
No, but you can try to set the geometry type on a per-feature basis using the postgis_type format attribute: file:///D:/Apps/FME2015/help/fme_desktop/FME_Desktop_Help.htm#../Subsystems/FME_Readers_Writers/Content/postgis/Writer_Directives.htm%3FTocPath%3DFME%2520Readers%2520and%2520Writers%7CPostGIS%2520Reader%252FWriter%7CMapping%2520File%2520Directives%7C_____2
darkspatiallord
Participant
In 2015 works - this is related to the other post you commented on.
In 2016 if you do as the above it isnt actually setting it correctly
Have tried all the tricks....
  • November 17, 2016
Have you tried telling FME to use a generic geometry column when creating the writer?
  • December 11, 2017
david_r - Link to your fil is't working any more. I have been trying to use Postgis_type in 2017.1, but I can't get it to work. Have any one succeed with this metode?
