polygon with single pair of coordinates,Hi
  • June 16, 2017
  • 4 views
Hi
I'm having a problem reading and then writing shapefile into MS SQL database. Shapefile contains multiple polygons (and multi polygons), but apparently there are few with only single pair of LAT / LON coordinates. These are rejected and not written. Is there a way how to write them anyway?
Thanks
erik_jan
Forum|alt.badge.img+18
  • June 16, 2017
I would use a Tester (@NumCoords() = 1) and a GeometryCoercer (set geometry to point) to avoid invalid geometries on the output.
