Oracle 12c - Bad Packet Error Resolution
  • Jun 22, 2017 3:35 PM UTC
  • 618 views
jbradfor
Forum|alt.badge.img+7
While converting from Oracle 11g to 12c, we executed a simple Oracle Non Spatial Workspace that moved 4 million rows from a CSV file to an Oracle table on 12c. It consistently threw the
ORA-12592: TNS:bad packet error after running for 30-40 seconds.
We ran the same workspace against 11g and it worked fine.
After researching the issue we ended up modifying the Oracle 12c Server SQLNET.ora file by adding this parm:
SQLNET.SEND_TIMEOUT=600
Modifying the client side SQLBET.ORA did not resolve the issue. Modifying the server side SQLNET.ORA file did.
steveatsafe
Forum|alt.badge.img+16
Hi Jeff, I'm really happy you've shared this with the FME Community. This may help anyone else that has recently moved to Oracle 12c and finds the timeout has changed on them. Great find!
erik_jan
Forum|alt.badge.img+26
  • Jun 22, 2017 9:24 PM UTC
Thanks for sharing this information.
Might be a good help to other Oracle users.
