OLD CSV reader fails in 2013 SP4
  • Nov 6, 2013 1:32 AM UTC
  • 15 views
kimo
Forum|alt.badge.img+10
When I go to run my scripts written in earlier versions the csv reader fails all features, but wastes time reading them all with no errors.
After fiddling around for half a day I found a workaround. Delete the old reader and add a new one with the same parameters. Just saving the workbench in the new format is not enough.
So I will have to edit every single script written that uses a CSV reader. Not Happy.
fmelizard
Forum|alt.badge.img+22
  • Nov 6, 2013 8:08 AM UTC
Wouldnt be either.....definitely an issue to report back to Safe!
  • Nov 6, 2013 8:25 AM UTC
I agree with Itay, report it to Safe.
You could also consider the solution I posted here some time ago. It should be more robust for this type of scenario.
David
