Open
Respecting field name length limitations and reserved keywords per feature write
Related products:Integrations
mb_fdfa
Participant
***Note from Migration:***
Original Title was: Respecting field name length limitations and reserved keywords per feature writer type
1) Field name length
As the maximum length of a field name in various formats is known (databases, shapefile, etc), it would be very helpful if FME Writers validated this on attributes entered.
https://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-sql-server/enterprise-geodatabase-limits.htm
https://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-oracle/enterprise-geodatabase-limits.htm
https://pro.arcgis.com/en/pro-app/help/data/geodatabases/manage-file-gdb/file-geodatabase-size-and-name-limits.htm
2) DB Keywords
In a similar fashion, there are reserved keywords which can't be used as field names in many formats - this could also be validated on writers.
https://docs.microsoft.com/en-us/sql/t-sql/language-elements/reserved-keywords-transact-sql?view=sql-server-ver15
Error messaging for this in the translation log could also be clearer.
Be the first to reply!
