NETCDF .nc4 and wrong dimensions
  • Feb 17, 2023 1:17 PM UTC
  • 136 views
Capture d’écran 2023-02-17 140932Hello, I'm currently working with FME 2022.1 on NETCDF files from https://daac.ornl.gov/cgi-bin/dsviewer.pl?ds_id=1851
The files are .nc4 and when I try to open them on FME Workbench I have this warning. (on picture)
It seems that FME can't link the dimensions defined in the file with its own "lat/lon and time functions"
I tried opening these files on ArcMap 10.8.1 and the dimensions are immediately recognized correctly.
How can I make FME understand that lat = lat, lon = lon and time = time ? Or how can I set it when reading the nc4 file ?
Best answer by kailinatsafe
Hello @nokram​, thanks for sharing the data link! It looks like the dimensions on this NetCDF file are ordered as: lat, lon, time, whereas typically dimensions are ordered as: time, lat, lon. This is completely fine and acceptable, but this is likely why you're seeing those WARNINGS printed to the logfile. All warnings aside, it looks like FME is reading the data correctly!
I'll file an issue with our development team to have these log messages removed (FMEENGINE-76677). In the meantime, it's safe to ignore the warnings! Happy to help, Kailin.
kailinatsafe
Forum|alt.badge.img+24
  • Feb 17, 2023 10:09 PM UTC
kevs-2021
  • Jul 11, 2025 7:10 AM UTC
I am having the same issue. Despite not a hot topic, it would be great to be able either:
1. Reorder the dimensions in FME
2. Shut down these warnings
The issue is that these warnings are logged in every transformer of the workspace.
Having 3000+ rasters in netcdf to process this error completely pollutes the Translation Log
Regards
-K
