Miss attributes when using FME to transform the model in ESRI file GDB to Cesium 3D tiles one by one
  • Jul 14, 2017 2:09 PM UTC
  • 70 views
My source data is the multipatch model data in ESRI File GDB format, I use FME to convert it to Cesium 3d tiles one by one, everything is good, but the generated b3dm no attributes, how can I solve??if i don't convert it totally?the b3dm file contains attributes,but the models are not Seperated?
LizAtSafe
Forum|alt.badge.img+27
  • Jul 17, 2017 10:58 PM UTC
Hi @kesai thank you for your question. Would you be able to share your workspace with some sample data, so one of our experts can reproduce your problem and come up with a solution? Also which version of FME and Cesium are you using? Thank you.
lars_de_vries
Forum|alt.badge.img+10
Hi @kesai,
Usually attributes are set on the 'User Attributes' tab of the Writer (your 2.jpg image). The easiest way to copy the attributes is to remove the Writer feature type, without removing the Writer itself. Next, right click the Reader and select 'Duplicate on X' where X is your Writer. Connect the new Writer feature class with the Reader feature class and you should have your attributes.
