Microstation Linetype
  • Mar 27, 2015 6:30 PM UTC
  • 69 views
I'm reading a GIS (LINE) feature class from an SQL database and trying to output it to a Microstation v8 .dgn.The line style I want to output is a fence pattern.  This fence patter is not pre-defined in the DGNStyler.  I have set the linetype in the SEED file and set "by level" in the DGNStyler, but no luck?  This fence style is not one of the standard 7 dash,dash dot...styles.
I'm not sure if I can somehow import that specific style into FME in order to be able to assign it to the output via the DGN Styler, at the moment there is only numbers 0-7 and ByLevel to choose from in FME?.
Best answer by pratap
If the style is menioned in template then you can key-in the linestyle through attribute
Pratap
pratap
Forum|alt.badge.img+12
  • Apr 16, 2015 8:18 AM UTC
Pratap
