How to set feature color transforming from ESRI shapefile to DGN?
  • Oct 2, 2020 12:04 PM UTC
  • 119 views
isis
Participant
Forum|alt.badge.img+3
I transformed SHP to DGN, but all features are in one color. I need to apply features in color set by level. Even with seed file set or DGN file with right colored features as a color source, features from SHP data are in the right levels, but have no individual color by level. Seems like transformer is putting SHP feature in right DGN level (by attribute) but with default color, not color by level.
Best answer by andreaatsafe
Hi @is​ ,
Can you use a DGNStyler for your features, prior to writing to your DGN file, and check "Color > Color By Level = Yes"
DGNStyler
This should now set the features to be the colour from the seed file.
andreaatsafe
Forum|alt.badge.img+17
  • Oct 2, 2020 6:25 PM UTC
Hi @is​ ,
DGNStyler
isis
Participant
  • Participant
  • Oct 5, 2020 8:47 AM UTC
Yes, it really helps - great to see features in colors after 2 weeks of monochrome result.
Thanks a lot, andreaatsafe!
