How to set the colour of the linetype of text to be 'by layer' in a DWG? I learned from https://knowledge.safe.com/questions/30155/how-to-set-bylayer-color-in-a-gis-to-cad-transform.html that autocad_color = 256 will set the colour by layer, not by entity (which doesn't make sense, but apparently is the answer, and it does work for me). However, this only works for lines and arcs - for text, the text is still coloured 'by entity'. I am transforming a DWG to a different configuration of DWG (seeing layer names, colour, splitting by an input layer, etc) so no major changes. I just can't figure out how to manipulate this particular item
