How to rename multiple rasters in FME
  • Jan 15, 2019 6:15 AM UTC
  • 107 views
Hi, I have many rasters in file gdb with lower case file names. I need to rename them by adding a prefix to all file names and also change their names from lower case to upper case. My goal is move them to ArcSDE after renaming them.
whkarto
Forum|alt.badge.img+14
  • Jan 15, 2019 7:57 AM UTC
User the StringCaseChanger to force your fme_basename attribute to UPPERCASE and an AttributeManager to add your desired prefix to the same attribute. Then do a dataset fanout on your desired writer and point at the previously created file name attribute.
itay
Forum|alt.badge.img+19
  • Jan 16, 2019 7:40 PM UTC
or just an attribute manager set to:
@jasper If you just want to rename files, without actually reading the data, then you can use a combination of the Directory and File Pathnames reader, AttributeManager to add the prefix and change case and then File Copy writer.
