How to read Multiple ArcSDE Tables and Writing Them to a File Geodatabase Using a Dynamic Schema
  • Nov 6, 2026 4:23 PM UTC
  • 0 replies
  • 4 views
gogopotter90
Forum|alt.badge.img+14
Hello everyone,
I'm facing an issue when reading multiple tables from ArcSDE and writing them to a File Geodatabase using a dynamic schema.
I'm using fme_feature_type as the destination feature class name. However, translation fails for some tables.
After investigating the issue, I found that some tables contain Esri-specific attributes such as shape.len and shape.area, and other esri objects which seem to cause problems when writing to the File Geodatabase.
My idea  is to automatically remove any Esri-specific attributes that might cause compatibility issues and then write all tables successfully to the File Geodatabase.
My first approach:
I'm working with FME Form 2024 and trying to clean up the schema before writing data to a File Geodatabase.
My workflow is:
  1. Use FeatureReader to read the source data and retrieve its schema through the Schema output port.
  2. Use ListExploder to split the attribute{} list into individual schema attribute definitions.
  3. Use Tester to filter out unwanted Esri-specific attributes based on the name attribute.
  4. Use ListBuilder to rebuild the cleaned attribute list.
  5. Connect the ListBuilder output to the File Geodatabase Writer's Schema port.
The problem:
After rebuilding the list with ListBuilder, the geometry definition (fme_geometry{}) is missing.
As a result, the translation fails because the resulting schema is incomplete.
My questions:
  1. What is the correct approach to remove unwanted Esri-specific attributes while preserving the original schema and geometry definition?
  2. How can I retain the original geometry type (e.g. geodb_point, geodb_polyline, or geodb_polygon) when rebuilding the schema?
  3. Is there a recommended way to dynamically clean schemas from multiple ArcSDE tables before writing them to a File Geodatabase?
What is the best approach to write data from ArcSDE to a File Geodatabase using a dynamic schema? I want the File Geodatabase Writer to automatically create the output feature classes and attributes based on the source schema.
