Modify Schema list attributes
  • Jan 7, 2025 9:39 AM UTC
  • 220 views
saravanan
Forum|alt.badge.img+18
I have a requirement to modify the list attribute generated on schema port.
Lets say my schema scanner have default attributes name, fme data type and native data type.
I want to look on name attribute and find any of its elements have OBJECTID string and remove if it is present.
I try to modify list attributes using python caller. It modifies the list elements when I overwrite using feature.setAttribute method it is not working and returns original schema attributes unmodified.
Any help using python would be highly appreciable.
Best answer by david_r
Try something like this in a PythonCaller:
# Generate a list containing a tuple for each attribute definition
names = feature.getAttribute('attribute{}.name')
fme_data_types = feature.getAttribute('attribute{}.fme_data_type')
native_data_types = feature.getAttribute('attribute{}.native_data_type')
input_schema = zip(names, fme_data_types, native_data_types)
# Filter out named attributes
attributes_to_delete = ('OBJECTID', 'MyAttribute1', 'MyAttribute2')
output_schema = [attr_def
for attr_def
in input_schema
if attr_def[0] not in attributes_to_delete]
# Need to explicitely remove all existing list items first, since
# simply setting new values does not automatically remove
# existing items outside of the range of new items.
feature.removeAttribute('attribute{}.name')
feature.removeAttribute('attribute{}.fme_data_type')
feature.removeAttribute('attribute{}.native_data_type')
# Set the schema feature attribute definitions
feature.setAttribute('attribute{}.name',
[attr_def[0] for attr_def in output_schema])
feature.setAttribute('attribute{}.fme_data_type',
[attr_def[1] for attr_def in output_schema])
feature.setAttribute('attribute{}.native_data_type',
[attr_def[2] for attr_def in output_schema])
Make sure to modify the contents of attributes_to_delete as needed.
  • Jan 7, 2025 9:46 AM UTC
Have you checked on the writer, some of them have a setting to remove/ignore named attributes. That way you wouldn’t have to modify the schema feature.
saravanan
  • Jan 7, 2025 9:54 AM UTC
Yeah this one helps to remove when known attributes. My requirement is to remove unknown attributes that generates on the fly.
  • Jan 7, 2025 10:48 AM UTC
for attr_def
in input_schema
saravanan
  • Jan 7, 2025 11:11 AM UTC
for attr_def
in input_schema
Thank you ​@david_r This is what I exactly looking for. removeAttribute is mandate before setAttribute.
