how to put quotes around stings when feature writer writes a csv?
  • Dec 7, 2018 12:34 AM UTC
  • 6 replies
  • 397 views
nicholas
Forum|alt.badge.img+14
I am using FeatureWriter to ouput a text file.
It does not put quotes around string attributes like it should.
I want
"2018-12-07 09:30:00","Canungra (Defence)",0
I get
2018-12-07 09:30:00,Canungra (Defence),0
The third column is numeric and should not have quotes
Best answer by nicholas
I solved it by switching the FeatureWriter from Format: CSV to format Test File
I used Attreibute creator to concatenate three columns into one (text_line_data) with " and , exactly where I want them.
I also used a Creator and AttributeManager to create the column names (separated by commas) as the first line
So, my solution was to avoid the csv writer and use the text file writer instead. More work, but far more control.
What I would really like is for the CSV writer to allow the quotes to be set on a column by column basis
nicholas
I tried StringReplacer and it does not work
danilo_fme
Forum|alt.badge.img+58
  • Dec 7, 2018 1:13 AM UTC
Hi @nicholas
I re-criated here your case with the AttributeCreator:
After, the transformer AttributeSplitter to split in " , ". The list of attributes was created:
_list{0}
_list{1}
_list{2}
I concatenated with StringConcatenator using this configuration:
"@Value(_list{0})","@Value(_list{1})",@Value(_list{2})
Thanks,
Danilo
nicholas
  • Dec 7, 2018 2:20 AM UTC
  • Dec 7, 2018 1:57 PM UTC
If you need to always quote the 1st and the 2nd columns, you can easily do it using the StringConcatenator with the Overwrite Existing Attributes option, like this. Assuming attribute names for the 1st and the 2nd columns are "attr1" and "attr2".
erik_jan
Forum|alt.badge.img+26
  • Dec 7, 2018 2:12 PM UTC
The Parameters for the CSV writer in the FeatureWriter contain these to add quotes to the output values:
nicholas
  • Dec 9, 2018 11:27 PM UTC
Setting "Qualify Field Values" to Yes will force quotes on all columns, including numeric fields. I do not want quotes on numeric fields
