How to get geometry from bridge modul in citygml?
  • Mar 30, 2023 5:17 AM UTC
  • 99 views
limo
Forum|alt.badge.img+8
we have a citygml file that contains a bridge. The validation by "citydoctor " showed no errors. Now we wanna extract the geometry. FME can read the file without error. But only a core element is shown and I cannot get the geometry!
By the way we got the same result with the template bridge from the university (KIT)!
Does anyone have any ideas or tipps for me?
Thanks in advance.
Best answer by itsmatt
Make sure you are using the CityGML reader. Check that you are not using the GML or XML readers. The CityGML reader will do all the work for you
itsmatt
Forum|alt.badge.img+48
  • Mar 30, 2023 12:40 PM UTC
limo
  • Mar 31, 2023 7:41 AM UTC
you are absolutely right!!!
I had imported the file via drag and drop. So FME has automatically set the format to gml and not citygml...thanks for you help!
