How to fanout CityGML without subfolders?
hth
Participant
  • Participant
Hello,
I would like to fanout CityGML-files depending on an attribute. As far as I know, I can use the dataset fanout. On CityGML-data it creates a subfolder and a CityGML-file in it, which have both the same name. The featuretype-fanout won't work (I guess), because I have to define roofsurfaces, wallsurfaces etc. there.
So is there a way to fanout CityGML without subfolders having all files in one outputfolder at the end?
Best answer by stalknecht
You can use a featurewriter and a systemcaller to do the trick:
The systemcaller will use a ROBOCOPY command.
gml2citygml.fmw
You can also solve this by:
  • Instead of using cmd files you can use a workspacerunner.
  • Use a python shutdownscript.
let me know what you prefer.
stalknecht
Forum|alt.badge.img+21
  • July 14, 2017
Can you provide a CityGML for us to test?
hth
Participant
  • Participant
  • July 17, 2017
citygml-testfiles.zip
Here are two citygml-files. Try to export them with fanout-option so you can get the same fme_basenames without any subdirectorys. The writer should look like this (perhaps without Address):
stalknecht
  • July 17, 2017
Must it only work in workbench or has the workspace to be served by fme server?
hth
Participant
  • Participant
  • July 18, 2017
It should work in workbench, but without any batch-scripts. I know, I can do it with .bat-files, reading one file after the other, starting the FME several times.
But in my case, I am creating the citygml-files within FME and want to use the fanout afterwards. So I don't use a reader to get them into FME, like the examples I posted earlier.
stalknecht
  • July 18, 2017
gml2citygml.fmw
hth
Participant
  • Participant
  • July 18, 2017
Thank you very much for the help!
The featurewriter and systemcaller with robocopy worked for me. I had to adjust a few things, so the featurewriter has seperate featuretypes like citymodel, building, wallsurface etc. and I am able to choose the save-drawner with a public Parameter on start. So everything is fine now.
