how to dynamically create a json
  • May 12, 2017 4:58 PM UTC
  • 5 replies
  • 280 views
arthy
Forum|alt.badge.img+8
Hello,
I implemented a changed detection on oracle table.
Now I would like to be able to create a json for each change per object.
 For instance, for an object where changes were detected on 5 attributs, below will be the json that I would like to obtain:
"ATTRIBUT1": {
"OLD_VALUE": "OLD1",
"NEW_VALUE": "NEW1"
"ATTRIBUT2": {
"OLD_VALUE": "OLD2",
"NEW_VALUE": "NEW2"
"ATTRIBUT3": {
"OLD_VALUE": "OLD3",
"NEW_VALUE": "NEW3"
"ATTRIBUT4": {
"OLD_VALUE": "OLD4",
"NEW_VALUE": "NEW4"
"ATTRIBUT5": {
"OLD_VALUE": "OLD5",
"NEW_VALUE": "NEW5"
How can I proceed to obtain this in fme?
I was tinking of the agregator to group all the changes from the same object (based on an objectid) and then build the json but I don't know how to proceed.
Please keep in mind that the number  and names of attributes will change from one object to another one.
Thanks,
Best answer by jdh
If I understand correctly, you have a separate feature for each change.
You can use the JSONTemplater, with a subtemplate to build your desired JSON.
see http://docs.safe.com/fme/2017.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/jsontemplater.htm, particularly the section "Selecting the Sub-Features to Process"
I would use a sampler to get the first feature for each objectID to the Root, and sent it as well as all the other features to the subtemplate.
jdh
Forum|alt.badge.img+41
  • May 12, 2017 5:37 PM UTC
arthy
  • May 12, 2017 7:39 PM UTC
@jdh,
Using the JSonTemplater and grouping on the objectifid as you said, I'm having having 5 json file but what I want it is only one json file.
Yes a change can only be made on one feature at a time. However, a change can affect several attribut of the same feature. In the example described above, we are having 5 attributes that were changes on the same feature
  • May 13, 2017 9:28 AM UTC
Hi @arthy, probably the JSONTemplater would be a solution, but template expression depends on how the feature contains the relevant attributes. What attributes contain the values which should be written into the destination JSON document?
jdh
  • May 15, 2017 3:06 PM UTC
@jdh,
Try a subtemplate of
{fme:get-attribute("Attribute"): {"OLD_VALUE": fme:get-attribute("OldValue"), "NEW_VALUE":fme:get-attribute("NewValue")}}
and in the root template
{fme:process-features("SUB", "ObjectID", fme:get-attribute("ObjectID"))}
or if you want the object id reference in the json object, something like
{"ObjectID" : fme:get-attribute("ObjectID"), "Changes" : {fme:process-features("SUB", "ObjectID", fme:get-attribute("ObjectID"))}}
arthy
  • May 22, 2017 9:46 PM UTC
@jdh,
I tried it and it works perfectly.
Thanks
