How to convert ESRI shapefile to CityGML by using an ADE with proper geometry(LoD)?
  • Feb 8, 2018 4:36 AM UTC
  • 6 replies
  • 245 views
I am having different dataset, that i have to convert to CityGML using ADEs.
When am trying to do this, TRANSLATION WAS SUCCESSFUL is displayed (eg: 780 features transformed)
BUt, when am viewing it in FME Data Inspector, "THERE IS NO GEOMETRY IN THIS VIEW" is shown
I am using FME trail version. LOG TABLE shows this: "The 'FFS' reader was destroyed successfully
Failed to display the table contents due to the following error:
The floating license environment variable LM_LICENSE_FILE is defined, but is ignored by FME. To enable FME to use LM_LICENSE_FILE, set the environment variable FME_USE_LM_ENVIRONMENT to the value YES."
please help me..
Best answer by daveatsafe
Hi @vishnuedakkat93,
The CityGML writer does have a fairly optimistic concept of success. If you would like to share your workspace, the ADE .xsd, and a sample of your source data, I would be happy to help you get the CityGML writing successfully.
daveatsafe
Forum|alt.badge.img+24
  • Feb 8, 2018 11:19 PM UTC
these are the materials used in the workspace.
try-network.fmw
transportationmodel.zip
vasantvihar-line.zip
@DaveAtSafe
daveatsafe
  • Feb 9, 2018 5:29 PM UTC
CityGML has a fixed schema, so you can only write the allowable feature types. To automatically add these feature types to your workspace, add a new CityGML writer, setting Feature Type Definition to Import from Dataset. When the Import Writer Feature Types dialog comes up, leave the Dataset blank, and click OK. This will create all the allowable CityGML feature types on the writer.
You also need to use the FME Hub transformer CityGMLGeometrySetter to set the CityGML Lod Name and Feature Role before writing.
For more detailed information, please see the CityGML Tutorial in the writer documentation.
Thank You Sir
Sir,
Good Morning
I am using SKetchUp (64 bits), ArcMap(32 bits), and FME (64 bits). System (64bits)
Does this change will affect the final integration of everything in CityGML format?
I got one suggestion that, Data/ output is not shown because of change in ArcMap and FME (bits) variation.
@DaveAtSafe
daveatsafe
  • Feb 13, 2018 6:32 PM UTC
Sir,
Good Morning
@DaveAtSafe
If you are using FME 64 bit, you must have the 64 bit Geoprocessing installed in your ArcGIS in order to read from some of the Esri formats. However, you should be able to read Shape files and basic Geodatabases without ArcGIS.
I am attaching a modified workspace that writes out the Roads from the Shape file you sent.m-14887-try-network.fmw
