How to connect to ESRI's versioned (e.g. QA version as opposed to default version) database using FME.
  • Sep 8, 2017 6:53 PM UTC
  • 62 views
lsugumar
Forum|alt.badge.img+4
Best answer by trentatsafe
Hello @lsugumar,
You can access a specific version of your database by setting the version on the reader located here
You can also set the version on the writer:
This article may also help you: https://knowledge.safe.com/articles/30729/tutorial-extracting-differences-from-an-arcsde-geo.html
trentatsafe
Forum|alt.badge.img+7
  • Sep 8, 2017 7:01 PM UTC
Hello @lsugumar,
lsugumar
  • Sep 8, 2017 7:59 PM UTC
Hi @trentatsafe
Thank you! I was able to connect to the version I needed.
Lavanya.
