How to connect to ESRI's versioned (e.g. QA version as opposed to default version) database using FME.
Best answer by trentatsafe
Hello @lsugumar,
You can access a specific version of your database by setting the version on the reader located here
You can also set the version on the writer:
This article may also help you: https://knowledge.safe.com/articles/30729/tutorial-extracting-differences-from-an-arcsde-geo.html
